Nu stiu cu ce sa incep!!!
Scris: 01 Iul 2017, 00:55
de Imeh1234
Buna ziua,
Am reusit astazi sa achizitionez un Vag com si se pare ca am gasit o gramada de probleme la seatul meu ibiza din 2002 1.4 6k daca are cineva idee de unde pot incepe sa repar la aceste probleme va rog sa imi dati un sfat.
Ce este mai important?
Masina inca merge daca sunteti uimiti.
Address 01: Engine Labels: ***-906-032-AKK.lbl
Part No: 6K0 906 032 C
Component: ME7.5.10 S066
Coding: 042**
Shop #: WSC 00000
VCID: **5F1E22C853165E********
10 Faults Found:
16955 - Brake Switch (F)
P0571 - 35-00 - Implausible Signal
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
16712 - Knock Sensor 1 (G61)
P0328 - 35-10 - Signal too High - Intermittent
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 35-10 - System too Rich - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-10 - System too Lean - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-10 - No Activity - Intermittent
Readiness: 0000 0100
