Salutare, cine ma ajuta cu ceva info legate de err. de mai jos?
Multumesc anticipat, fac cinste , nu-i problema!
As merge la reprezentanta, dar sincer din proprie experienta cand vine vorba de electrica, tot ce fac este sa taie mufe.. In plus, nu pot reproduce eroarea si daca o sterg, apare peste 1-2-3zile.
Azi le-am sters, am inchis usile in toate felurile,dechis din telecomanda,trantit, etc etc. am mers cu masina puternic, curbe,linii de tramvai etc etc... am oprit, am scanat si ...nimic.
(mentionez ca "fizic" nu observ nici o defectiune.)
Sunt 4 erori, din care 3 cred ca sunt legate intre ele, iar a 4-a nu sunt sigur (banuiesc ceva legat de alarma? dar ..)
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
62-Door,Rear Left -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: E38E0F2F00041000001D00000000000000017F075C
Shop #: WSC 06441
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00137517
Shop #: WSC 06441
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 57754 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Coding: 7D3F03C007000202
Shop #: WSC 06441
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 57754 km
Time Indication: 0
Date: 2000.00.00
Time: 08:04:10
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Coding: 998000005283CC7F0006050560084F86307C00
Shop #: WSC 06441
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06441
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Time Indication: 0
